Quick check on what I'm ordering please
28 Jul 2004
My latest watercooling adventure was back in 2006 (and it's still running): http://forums.overclockers.co.uk/showpost.php?p=6412176&postcount=87
Now have a newer ITX PC and would like to try again. Could you check my basket please? I am particularly confused by the fittings and tubing.
Are those barbs going to fit on everything? CPU block, res and pump?
Same basket as OP, but it has some improvements and everything fits together :)
Also, i've added a res
YOUR BASKET
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x EK DCP 4.0 Pump (12v) £39.98
1 x EK Supreme LTX CPU Waterblock - Nickel Acetal £32.99
1 x EK Reservoir Combo DCP 4.0 £24.98
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) UV-Reactive Red 3.3m £10.88
8 x OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish £1.68 (£13.44)
Total : £184.27 (includes shipping : £10.00).
I presume you have fans and some fluid?
Nice, thanks.
I've already ordered but got everything you said except the tubing, I got the 16/10mm stuff. Hopefully it works out.
Don't think it will work :(
7/16 is tight enough as it is... 3/8 is even smaller
EDIT: if it hasn't despatched already, a quick call or posting in the CS section could get it changed :)
I'd also change the rad to the EX as it is considerably btter :)
