Cable braiding/tubes help
15 Nov 2011
Oxford
HI, i would like to braid the cables in my case but rly do not have the time to do so atm, are there like plastic tubes that you can wrap around the cables?
thanks
yes, you can get them, but personally i think they look horrid which is probably not what you after if you talking about cable braiding (asthetic)
i;d point you in the direction of sleeved extensions like these:
http://www.overclockers.co.uk/productlist.php?groupid=1929&catid=1898
EDIT: i recommend you look at the birfenix alchemy range - very nice
http://www.overclockers.co.uk/search_results.php?sortby=&groupid=&search=BitFenix+Alchemy+braided
Thanks for that, will prob to that :) would look nicer :)
