Another newbie...
i did also change Rad to sr1 and reservoir to xspc - couldn't justify to spend nearly £70 on bay reservoir. But I'll change (read - mod) the Faceplate to adjust to my needs.
That was my main concern- to do not crack the block. Oh well. Will give it a go. Hopefully it will be right.
Meh, if I haven't managed to crack something, I doubt you will! I suffer from PEBKAC. TBH, I'm surprised people follow my advice at all!!
Tighten only by hand and it'll be ok :)
EK bayres is £45
Have received parcel from OC on Wednesday.
Still awaiting for rad, gpu block and some fittings.
I'm a bit disappointed with xspc reservoir. They could have done better job wit it. Even the faceplate is different, that this one on the oc website. I should have gone for koolance reservoir.
I'm looking now for fan controller. Anyone has Lamptron FC touch? I've read some reviews, and it seems to have some issues.
Why? I would like something without knobs.
I've seen that fc touch its not that responsive as it should be. Another thing if you connect 2 or more fan to one controller - which I'm intend to do - fan on the display stop rotating. And finally - light that can be seen coming from behind the top edge of the face plate. For £50 product it should have these issues.
Another parts have arrived GPU block, some fittings and a rad. But look what they did to it???
For a look of it, I think it was damaged by courier company. But I'll blame company who has posted it. It was really poor packaged. I don't know what they were think of. The problem is now I'll have to send it back and pay for postage, which I'm not really happy to do so. And the rad is out of stock now. So this means another delay. I'm so angry about it. I thought that I'll put all this together this Saturday. :mad:
Obviously not OcUK! They overpacked 500 plastic fittings with loads of those air cushion things!!!
You shouldn't have to pay for postage, just return saying goods were DOA
Yes, I know. Unfortunately OcUK didn't have rads in stock and I was in the rush.
I've read their t&c, and they clearly stated that they will not cover the cost of postage.
Its not easy to dammage a rad like that. :( haven't seen one like that on the net in a long time. Normally it has to be dropped from a hight.
Mind you the way couriers are now a days nothing surprises me.
Rad has been send back. I manage to sell xspc reservoir, so now waiting for this one.
Also still waiting for backplate for me 580. The company which I've ordered from (the only one in UK, which has them in stock) for some reason run out of the stock. I thought if you are buying something it should be allocated to your order. But it seems to this isn't a case.
Just order from OcUK
