- 11 Dec 2005
- Cheshire
Today only we have 45 units of the fantastic Corsair Vengeance 16GB dual channel kit. Featuring epic speeds and maximum capacity, perfect for any gamer. For only £95.99 inc VAT.
We also have 25 units of the epic HIS ATI Radeon HD 6950 IceQ 2GB graphics card, with dazzling DX11 graphics and an immense amount of VRAM. Yours for only £215.99 inc VAT.
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Dirt 3 PC Game** @ £215.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Special IceQ Cooler taken from 6970 and custom fitted to 6950 by HIS for upto 18c better cooling
- Great OC Potential
- OcUK Exclusive
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Dirt 3 PC Game
Only £215.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CMZ16GX3M2A1600C10) @ £95.99 inc VAT
The new 16GB Vengeance DDR3 kits operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Modules
- Each twin module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £95.99 inc VAT.
ORDER NOW
Features:-
- OcUK Exclusive
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features
- 8GB Modules
- Lifetime Warranty
ORDER NOW
