Water for what
tap warm.So it starts to burn your hand.
I'd max it at 70 Degrees, at least then its not going too. If it does then change your pump.
Be careful when running 70c or higher though you system. I have cracked 2 reservoirs both from xspc when we were running tests with water at 70c. Just a warning for you.
Is that all ?![]()
Is that all ?![]()
That's the max mick has even saying but he said it lasts for 12 months I think.
