Corsair Hydro 80
30 Mar 2011
Hi im just about to buy one of these but am a bit confused on a few details.
When I plug into cpu fan header will it control fan speeds or will it run on hydro preset settings. Would be nice for fans to be at speeds governed by bios to keep it quiet as possible but automatically drive it hard when pushing cpu
Have also read that you dont have to plug into cpu fan header just plug molex in, is this true(would have to turn off all fan monitoring in bios) and is this best prefer first option.
Thanks in advance for any replies but am finding a good google search very confusing.
Nigel
Not sure about this, but I'm pretty certain the H100 uses software for fan speeds which I believe is from the fan header.
TBH, you'll be much better going for a noctua DH14
The fan(s) plug in to the pump body. Circuitry inside the pump body control the fan speed according to one of three preset profiles.
No. The cpu fan wire is so you can see the pumps speed in the BIOS or monitoring software you use. The fans run on 3 different profiles, with a set RPM range.
Hers a link that explains the different profiles http://www.corsair.com/blog/understanding-the-hydro-series-h80-and-h100-cooling-performance-profiles
Each profile has a set RPM range that it will run the fans at. The fan speed will increase to the upper RPM limit of the selected profile as the liquid temperature rises and lower the fan speed when the temperature allows it. This allows the fans to run quieter.
Have also read that you dont have to plug into cpu fan header just plug molex in, is this true?
I would think so, yes.
I've left my cpu fan header at 100% doesn't make a difference I dont think, but you can still use your other fan monitoring headers.
I have just installed a H80 and connected it to the Molex and have not connected the other wire. I connected the two radiator fans to the pump.
I set the fan speed to max on the pump but the fan speed varies depending on load as when i game the speed rises then goes slower when web browsing etc.
BTW my OC'd Q9650 now @3.6Ghz runs at no more than 49 degrees when gaming so i am well chuffed.
I guess the other wire can go to the CPU fan header to see what RPM they are turning at.
That is correct, the fan speed will rise as the pump detects that the liquid temperature has risen. Setting the fan to high speed profile 3 will not run it at max all of the time, only when a rise in temperature according to that profile is detected.
