- 22 Apr 2009
- North-West
The S107G is amazing, survived a few horrific crashes and being attacked by the cat!!
If you use Groupon, there's an offer under Cardiff for an RC Helicopter. £21 down from £45.
Haven't got a clue if it's any good though.
http://www.groupon.co.uk/deals/cardiff/extreme-fliers/2276104
13 hours left to claim
Do most model shops sell the s107? Really tempted to pop down to the model shop to see which ones they have instead of getting it off the jungle.
i dont think so , modelzone do thoughDo most model shops sell the s107? Really tempted to pop down to the model shop to see which ones they have instead of getting it off the jungle.
spent £300 yesterday on blade MCPX, phoenix sim with DX6i.
spent hours on sim, brilliant. crashed the mcxp after 10 secs and snapped off the tail boomlol
If you lasted 10 seconds I'd say you did pretty well. When I first started learning to hover, I was crashing in under 2 seconds. It was in the air and crashed before I even noticed what happened.
Buy a length of 2mm solid carbon rod to make mCP X tail booms, and run the tail motor wires spiralled around the outside of it. They're stronger than the hollow ones, and you can make them about 15mm longer than the stock boom for better tail authority.
Here's a pic of my choppers. It was taken with a cruddy iPhone 2G as my camera battery dead after I'd lined them all up:
The other Trex 500 (white canopy) is my Dad's, and the Fusion 50 isn't in the pic.
Been playing around with the S107G which arrived today. Taking some getting used to but I'm slowly getting the hang of it.
I just keep panicking when it gets too close to inanimate objects and just dropping the throttle to 0 instead of trying to avoid. But great fun!![]()
google for "rc shop yourarea" and youll probably find some fairly close rc specialists that sell a wide range
the s107G is pretty slow in any direction other than up/downmy sons has had quite a battering , the little yellow thing on the end of the tail boom has a snap in it but ive duct tapeds it back on.
not sure if its actually needed or not but i thought for balance sake i best keep it attached
if you build your own dont you need tools to make sure its perfectly balanced , calibrate the electronics etc?
what would you make anyway a 6 channel?
aparently this is a good read if your wanting to learn how to control a proper rc heli http://www.dream-models.com/eco/flying-index.html
you need 5 channels for collective pitch helis, i'd imagine a 4channel fixed pitch heli wont feel all that different to the 3/3.5 channel toy helis
