I have connected a Hazro H27WC to a AMD Radeon HD 6670 using Dual DVI and after a few hours of use I sometimes get coloured "sparklies" appearing in all mid-grey areas. The problem persists if I turn the monitor "on and off" or if I change resolution from the Catalyst Control centre but it goes away if I reboot.
This leads me to suspect the graphics card, but I'm not certain. If I shift the card & monitor to another PC it's exactly the same - so I think that rules out my MB/PSU etc.
I'm now waiting for it to happen again so I can swap-in a different monitor and see if the sparklies persist or not. However I will have to swap DVI cables and drop the resolution to do this and so I'm wondering if this will indeed be a rigorous test for ruling in or out the Hazro monitor...? Maybe someone here recognizes the symptoms and can help point me to the source of the problem.
 but does have issues.
) or you gfx card.
