Guys,
Hope you can help.
I have an old core2duo desktop that I run as a HTPC running media portal with numerous DVB-T and DVB-S Connections.
I now have to run my PC about 3m from my TV (it used to be 0.5m).
I used to run a DSUB cable at 1080p with no issues at all, bought a new 'high quality' 3m Dsub cable, and it looks awfull, trully awfull - with the display white smearing all over white instances on the display - Tried a few cards, the same result on all.
Should i just invest in a better cable? or should i consider moving to HDMI?
What PCIE Card Can i install (on a budget) that will allow me to connect to the TV via HDMI with sound included.... note that I do not have a 2 pin spdif, or the room for an additional soundcard.
I read somwhere that the Nvidia 200+ Series now no longer need a cable. Can someone enlighten me please?
Hope you can help.
