Thinking of going watercooled
Thats very true!
Just been messing about with loop layout etc on paint. I personally think this would be the best route!
Just hope I have enough angle fittings!
What do you gouys think?
Update guys!
Recieved my pump with top (EK Waterblocks EK-D5 X-TOP - Acetal G1 / 4 Rev. 2)
However guys, I'm stuck which is inlet and outlet (Inlet = Res to pump) (outlet = pump to ...)
Any way guys, here is a picture of it!
I guessed the middle one is the outlet?
Need to buy some fittings aswel which I never knew about and won't get it till monday :(
Thanks guys!
Cheers, your a star!
Not sure if I will be doing all the watercooling this month, as I want to pick up a 2nd hand 480 and watercool it, but that won't be till next month.
So thinking of just waiting to get the GPU then watercool.
np :)
I would personally do a ghetto loop which should take maybe an hour. Then do your proper loop later. This way you can still DSR when needed and you can have a silent computer
