There are two questions that I am unsure on.
1)
The wording seems almost exact except for the angle and mass yet in the solution it shows the first answer with the force pointing up, but on the second one it shows the force pointing down. I get the same answer anyway it is just negative but I want to know how you know whether the force is pointing up or down. Here are the diagrams for both..
1)
2)
1)
2)A light inextensible string passes over a smooth peg, and is attached at one end to a particle of mass m kg and at the other end to a ring also of mass m kg. The ring is threaded on a rough vertical wire as shown in the diagram. The system is in limiting equilibrium with the part of the string between the ring and the peg making an angle of 60° with the vertical wire.
Calculate the coefficient of friction between the ring and the wire, giving your answer to three significant figures.
A light inextensible string passes over a smooth peg, and is attached at one end to a particle of mass 3m kg and at the other end to a ring of mass 2m kg. The ring is threaded on a rough vertical wire as shown in the diagram. The system is in limiting equilibrium with the part of the string between the ring and the peg making an angle of 30° with the vertical wire.
1)
2)
