Last Minute Lookover, and a question
24 Dec 2011
About to purchase, final thoughts on choices etc? Going for budget, so any cheaper versions/etc appreciated.
And the question; ocuk keeps randomly going down for me, that shouldn't cause a problem with purchase should it?:rolleyes:
You want a K version of the CPU, dont forget to use the code AG15 to get 15% off case & PSU, and no, it shouldnt
Good lord, must've added the wrong one to the basket :eek:
Thank you sir!
And yeah, the AG15 is applied already - Prices are adjusted in basket if you apply it then go back.
Besides the 2500k being a better choice as mentioned above, I'd point out, just in case you didn't notice, that the CPU cooler is out of stock at the moment.
EDIT: Possible alternative here, has plenty of good reviews.
And everything else looks sweet.
hmmm... do you need an OS, HDD or optical drive?
Other thought would be building an i3 rig with a more powerful GFX card?
