Hi,
Its been some time since I built my current pc but I am now looking to update it and use it as a gaming PC.
I will be playing the usual stuff BF3, Diablo, WoW etc.
Budget is about £800 including GPU but I will hang on buying one until the new stuff is released. I will then decide if to adopt a new offering of get one of the existing ones after a price drop
What I have is the following: -
Antec P182 case with a Corsair HX520w PSU and a Scythe Ninja. I have 1GB SATA Hard drive for Data, a copy of Windows 7 Professional on current PC which I will reuse and a SATA DVD RW drive.
I have a couple of question
1. Is the Power supply OK or should I just out that? not looking to do SLI as I know it wont do that.
2. The Ninja is 3 years old so not the latest. I have to dig out the box in the loft to see if it has an LGA1155 mount bracket as I currently have the LGA 775 fitted. Again should I keep or ditch? I plan to over-clock to 4.4 to 4.6 GHz.
The spec I have got down without GPU is the following: -
Product Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £161.99
(£134.99) £161.99
(£134.99)
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £159.98
(£133.32) £159.98
(£133.32)
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £87.98
(£73.32) £87.98
(£73.32)
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) £39.98
(£33.32) £39.98
(£33.32)
IC Diamond 24-Carat Thermal Compound (4.8g) IC Diamond 24-Carat Thermal Compound (4.8g) £14.99
(£12.49) £14.99
(£12.49)
Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin £13.99
(£11.66) £41.97
(£34.98)
Sub Total : £422.42
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £86.38
Total : £518.30
Cheers
Steve
(£134.99) £161.99
(£134.99)
(£133.32) £159.98
(£133.32)
(£73.32) £87.98
(£73.32)
(£33.32) £39.98
(£33.32)
(£12.49) £14.99
(£12.49)
(£11.66) £41.97
(£34.98)
Sub Total : £422.42
DPD Next Day Parcel
Total : £518.30
Cheers
Steve
