- 23 Jul 2009
- Shropshire
hi, am looking for the firmware for  DG834(G)-V3, cant seem to find it anywhere. anyone happen to have or no where to get?
thanks
			thanks
thanks
.Mines been on modem for years, it only supports fully bridged i.e. in modem mode it doesn't assign ips. The only options under lan should be router ip and sub net mask. I found assigning the modem a static ip then rebooting both it and the router was all that was ever needed. If the router defaults to 192.168.0.1 and the modems taken it the router will just have something else.
This issue is one of a couple reasons it's so much easier having the modem on 192.168.0.1 and the router/everything else on 192.168.1.x.
 . However when on DG834GT_V1.03.22_DGTeam_1018_eng_adsldrv023o.img it doesn't work (just like how on a DG834Gv5 with the Netgear firmware you can set it to modem mode but it doesn't actually make the change).
. However when on DG834GT_V1.03.22_DGTeam_1018_eng_adsldrv023o.img it doesn't work (just like how on a DG834Gv5 with the Netgear firmware you can set it to modem mode but it doesn't actually make the change).If it works on Netgear v1.3.23 why dont you try DGTeam DG834GT_V1.03.23_DGTeam_1012_eng_adsldrv023o.zip ?
 , ta.
, ta.That appears to be working, ta.
Do you just pick it and flash the firmware like any other router? Nothing special to do before I try mine with this firmware? I'm running Netgear stock 1.3.23.
