2700k Temp
Do you mean 124C is the temp for all 4 cores added together? If all the cores are around 30C each then thats fine
I agree with the post above, if the combined temperature is 124 then it should be fine, when your posting temperatures you dont post the combined temperature of the cores, just the temperature the core/s are hovering around, as in your second post if all the cores are approx. 30 degrees then thats fine :)
sunny download coretemp and/or realtemp, these are better for temps than speedfan imo.
also in future, list the individual core temps, not the total ;):)
to really test your H100, download intel burn test or prime95 and do a stress test,
just go by the highest temps, (individual),
then get overclocking :D
thanks guys
Used realtemp
Tj Max 98
Power 6watts
Min Max
Core 0 26c 30c
Core 1 25c 33c
Core 2 25c 32c
Core 3 26c 35c
how do those look ?
Ran Intel BurnTest
All went good ! Said cpu is stable
Max temp were around 50 - 56 for each core !
Those temps are good very good, i was the 1st to answer your post & didnt realise you were adding all cores together lol.
The norm is to take an average
thanks guys
Used realtemp
Tj Max 98
Power 6watts
Min Max
Core 0 26c 30c
Core 1 25c 33c
Core 2 25c 32c
Core 3 26c 35c
how do those look ?
Ran Intel BurnTest
Did you run IBT on Max Stress Level ?
thanks guys
Used realtemp
Tj Max 98
Power 6watts
Min Max
Core 0 26c 30c
Core 1 25c 33c
Core 2 25c 32c
Core 3 26c 35c
how do those look ?
Ran Intel BurnTest
you have a 2700k at stock on a h100 and your happy its stable?
i wouldnt be happy until it was at 4.8ghz stable with that cooler
my 2700k temps are same/lower than yours and im at 4.8ghz 24/7 but using a chiller.....what fans do you have on the h100 and what way have you installed them?
Max temp were around 50 - 56 for each core seems high for stock on a cooler thats £100 imho
I got the GT typhoons on the 600t corsair case
My windows also starts to lag from time to time and then it goes back to normal, anyone know the problem or has it as well ?
I was converting a video(Xilisoft) and around 95% the CPU % went from 50% to 0% and then it just stayed around 10%
IS there a problem with my system ?
