Hi there
Posted the other day about a spec, and looking at my budget I'm unsure which of these to go for. I would appreciate your advice on what you would recommend.
It's between these two for the PSU:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-XF
http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123&subcat=1084
And these two for the case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-BX
One is £10 cheaper for today only, but the other seems to have a better finish (from the reviews).
Thanks!
Thanks!
I would like to see whether people rate the Zalman Z9 above the Bitfenix Shinobi?
