- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
OcUK is the only place you can pre-order the new legendary Cosmos 2 Ultra Tower Case from. With stock due the first week of Feb now is the ideal time to pre-order the "beast".
Cooler Master Cosmos 2 Ultra Tower Case - Black @ £339.98 inc VAT
The flagship case of Cooler Master - COSMOS II, is defined as the “Ultimate platform for extreme performance”. Its streamlined design with aluminum and mesh makes this product incomparably stylish and luxurious. It supports up to 10 fans, 13 HDDs, and 4 Way SLI/CF; also features an Advanced Control Panel for fan speed adjustment with LED indicators. The rich I/O includes 2 high speed USB 3.0 ports for quicker data transfer. The combination of its elegant looks, numerous expansion options, and functionality make the COSMOS II a definite choice for a user’s “Dream Case”.
- Stylish and streamlined race-car inspired design
- Brushed aluminum and steel for strength and elegance
- Airflow optimized design
- Supports up to 10 fans and 13 HDDs (2 from X-dock)
- Supports 4 Way SLI/CF
- Supports XL-ATX / SSI CEB / SSI EEB boards
- Advanced Control Panel:
- 4 channel fan speed control
- Materials Appearance: Aluminum, Mesh, Plastic/ Case body: Steel
- Dimensions: 344(W) x 704(H) x 664(D)mm / 13.5 x 27.7 x 26.1 inch
- Weight: 21.5kg
- M/B Type: Micro-ATX, ATX, E-ATX, XL-ATX, SSI CEB, SSI EEB
- 5.25" Drive Bay: 3
- 3.5" Drive Bay: 13 (2 from X-dock, Middle cage for 5 HDDs, Bottom cage for 6 HDDs:
- 2.5”/3.5" Drive Bay 11 (converted from 3.5" bay)
- I/O Panel: USB 3.0 x 2, USB 2.0 x 4, E-SATA x 1, Audio In and Out
- Expansion Slots: 10+1
- Front Cooling: 200mm LED fan x 1 (converted from 120/140mm x 1)
- Top Cooling: 120mm black fan x 1 (converted from 200mm fan x 1/ 140mm fan x 2 / 120mm fan x 3)
- Rear Cooling: 140mm fan x 1
- Side Cooling: 120mm fan x 2 (optional)
- HDD: 120mm fan x 3 (2 for bottom HDD / 1 for Mid. HDDs)
- Maximum Compatibility: CPU cooler height: 190mm / GPU card length: 385mm
Only £339.98 inc VAT.
ORDER NOW
- Weight: 21.5kg
ORDER NOW
