Right, I may have too much time to think at work but this came into my head last night and I don't know If i'm making it out to be more complicated than it is.
Imagine there is a pill you could take, 6 hours after you take it the past 6 hours of your memory are erased.
You take the pill before you head to work (let's assume you don't like your job in this situation and wish it passed as quickly as possible.) You then go to work normally and do your thing, time passes as it normally does, you do all the work you normally would.
6 hours later you return home and the pill kicks in and your memory of the past 6 hours is wiped. At this point it would appear to you as though only a second ago you were taking the pill, and time has passed almost instantly.
So, in this respect it would be worth taking the pill, since after taking it you would have been to work and apparently done it all instantly. But at the same time you would have had to have worked consciously and aware like normal up until the 6 hours was up, which in turn also makes it pointless.
Am I being dense here or does this confuse anyone else?
