Effective cleaning
29 May 2005
West London
So my girlfriend's A1 is arriving anyday soon, and we've decided we should keep it nice and clean, as you do.
What's the best apparatus we should purchase and what methodologies should we use? Do we need to get a polishing machine?
What about interior? It's leather, what products should we use?
Two buckets, wash mitt, hose or pressure washer with foam lance if you see the need.
Hoover for the inside, job done.
Wash and hoover it once a week and it will be better than 99% of the cars on the road.
Would advise against a polishing machine on such a new car.
I generally use:
Meguairs NXT shampoo
Autoglym Super resin polish
Meguairs Carnuba Wax
The for the other bits:
Autoglym Tyre shine
Autoglym Alloy Wheel Sealent
Autoglym glass polish
Autoglym Tyre dressing
Autoglym interior shampoo
+ plenty of microfibre cloths and sheepskin mitts etc
There are many sites/forums that could advise you on this. So many products and techniques you could use!
Some people even polish a brand new car to get rid of 'orange peel'... but thats a whole different ball game.
Thanks Nath, is that the order we should apply them in?
I would ask on other forums, but they seem into detailing etc more than I would like to be!
There are loads of ways to wash your car mate.
I won't go into too much detail but a quick brief of a "normal" car wash for me is:
Car
- rinse
- wash with shampoo
- rinse off shampoo
- dry with drying cloth
- Polish glass
Wheels
- rinse
- apply wheel cleaner
- wash with shampoo
- rinse off
- apply tyre dressing
If I am going full monty on the car it would go like this:
Car
- rinse
- wash with shampoo
- rinse off shampoo
- apply polish
- apply wax
- polish glass
- interior shampoo + hoover
Wheels
- rinse
- wash with shampoo
- rinse off
- apply allow wheel sealant
I've highlighted in yellow the extra things I have added to the list.
Hope this helps.
Car
- rinse
- wash with shampoo
- rinse off shampoo
- Polish glass
Wheels
- rinse
- wash with shampoo
- rinse off
Car
- rinse
- wash with shampoo
- rinse off shampoo
- apply polish
- apply wax
- polish glass
Wheels
- rinse
- wash with shampoo
- rinse off
Hope this helps.
You make me feel like im abusing my car, i've only done one or two of those things :(
I'll probably be flamed by the detailers but I always give my cars a squirt of wax when drying them. Wax It Wet is my weapon of choice but if I find something cheap I'll use any brand I've heard of. Currently using Nano Tech Wax or something like that which I picked up for £2 a bottle.
I do this every wash and always get compliments on my car from 'normal' people but I'm sure the sort of person who owns a paint gauge wouldn't be impressed.
Once a year I give it the full wash, clay, polish, carnauba wax treatment.
SRP is exactly that, it has little / no cut. It's a filler, hence the name "Resin"
It is also a (very) mild abrasive hence the name "Polish".
If you use SRP on plain paint (i.e. no clearcoat) the rag turns the same colour as the paint so it must have some abrasive action.
A new car, in theory should arrive with mint condition paint work, though this is sadly rarely the case. Dealers clean them with dirty sponges causing all manor of horrid swirls.
My next car, I think I'll treat it to something like -
Ceramishield by concours - http://www.concourscarcare.com/ceramishield. Gives a good protection which they say will last 18 months or so.
I'd then just do what the others say - two bucket washing, clay and wax blah blah blah.
www.detailingworld.co.uk - have a look over there, very friendly bunch...
Edit -
http://www.detailingworld.co.uk/forum/showthread.php?t=243738
Some detailers are in this thread who will be able to offer some good advice (RussZS, is it?!).
Meguiars Cleaner wax is very easy to put on/off and gives a great shine.
