please point me in the direction of where in battle log it compares the effective range of the different assault rifles ??
It doesn't, they are all the ****ing same. Which of course they aren't. And theres no ratings for damage etc.. Its just shoddy and rushed.
)Just wondering... I saw that GUI and was wondering what is it for? Is it purely just for show or are they actually putting it in the game and when?
Also how to you change the look of the soldier on your stat/profile page thing?
Cheers
That GUI was just a mock up to show DICE how it could look like with a little effort.
And go to edit profile > soldier settings, click the pic
wth?
i keep getting kicked by pb for 0 minutes![]()
Update PB manualy, new update out.
2012 and PB still can't update the client automatically in or out of game, embarrassing TBH as it was the same with BF2.
Cheers
Same![]()
Voorhees cheers for that, i just noticed the board you have and thats the same one i have been looking at getting for an i5 upgrade. How do you find it? It seems to be a good budget board and im not looking to cross fire or anything like that just wanna try and get an OC of around 4.2ghz-4.5ghz with it
Hey m8, board is really good so far. Not a single issue and very easy to overclock. To overclock you can get 4.6 just by changing a couple of numbers. I have 4.6 stable with all tests with a venom cooler. In fact this will tell you what to change, it says 4.7ghz but I could not get it stable at all (bsods when gaming) so I went to 4.6 for 24/7 usage.
http://www.kitguru.net/components/m...68ap-d3-z68-review-bargain-buy-of-the-year/4/
The pictures show you to change the turbo to 47, so do 46. I mean your CPU may be ok at 4.7 but mine was not. Temps are also very good with air at 4.6ghz.
SoF? 2 months shy of 12 years.
