- 6 Aug 2008
- Birmingham
Also mobo is from OCUK but not CPU!!
Im on SP1
Is there something I need to do then?
SP reinstalled also chucked in some more mem
is this looking better?
Snip
@ reygjabla
That's fine unless you do something which causes obvious physical damage as OcUK won't be able to return the processor to Intel.
don't run Prime and IBT together. that why you seen a drop in GFlops
yes, you have to remember there background tesks using the cpu alsoBTW when I go to maximum it takes much much longer to run and the GFLOPS stay steady but fall quite a bit, is this normal?
