I just need to match up the referrence codes now so i don't get the wrong one..
The Asus 570 DirectCU II is reference?
. It worked for me as I have a top end 570 and it also has the 580 block not the standard 570 which was a good decision, as I was about to just buy the 570.
Not sure if I am able to mention this ? but EK do a watercoolingconfigurator not giving the link encase I get told off (Google has the answer though) but you go through the stages and select you exact card and it tells you all your block options. It worked for me as I have a top end 570 and it also has the 580 block not the standard 570 which was a good decision, as I was about to just buy the 570.
Regards
Ninja
if you want to buy anything off EK that we dont list.
get the EAN number for it and post it in the pre sales queries section
5UB will then forward it to me and I will get the part in for you if you want to order from OcUK
we can get anything listed on the EK site![]()
