Nvidia Kepler vs 500 series specs released - **HOLY CRAP**
what are the differences between the crappy graphs that came out for the 7970 and the actual results posted now? I remember seeing some stupidly exaggerated graphs.
There always are... For the last few GPU releases there have been a wave of obviously faked charts "leaked" all over the place - the vast majority of them completely and utterly fake.
Once we get some specs (HOPEFULLY this month), then we should have a rough idea of performance. Beyond that we'll have to wait until cards start showing up in the wild before we get any *real* info (so, a couple of weeks before release).
i like how people arnt noticing the % on the side, they seem to think the card will be 2x as fast just because the bar is twice as big :P
Note to muppet that wasted time on this: If you are going to fake a GPU's performance before it's launch then do it for 1 card not the entire range!
oh those are fps, ithought they were percent, and i meant op :)
Presumably they're fps, who knows? There's nothing on the graph that actually states what the numbers stand for. I'm still putting money on my Cornflake theory posted above, or perhaps Frosties? :p
Most rumours suggest they will be called the 7xx, to bring them in line with AMDs naming scheme (so they appear to be of the same generation as the AMD cards).
I really don't think AMD's the reason. Note that this series started with a process /architecture jump named the GTX 200 Series. 100 series was reserved for OEM and/or mobile parts iirc.
Then they skipped 300 which was again OEM and mobile parts and named their retail line GTX 400 series. GTX 500 was a tweak of 400 so no big jump there. (Same process and architecture).
But again GTX 700 series will be a new architecture on a new process, and 600 will be OEM/mobile parts.
So a pattern's starting to emerge. It may not be precise or strictly consistent, but there seems to be some order to (at) the (edge of) chaos. The one thing that sorta disturbs this pattern is when they then did refreshes of GTX 280 on a new process and called it GTX 285. And it's only the 280 that became the 285. The 275 had no counterpart and neither did the 295. And there was no GTX 265.
It seems to me to have been the theme from the beginning, with a bit of faltering along the way. Betweennew architectures they have always stuck to the jump of 200 for each cycle. Within these architecture jumps they've been inconsistent. (So while short-term predictability seems precluded, there is some long-term predictability :D ).
If they wanted to have a higher number than AMD they already had that when they were running the 8000GTx series alongside AMD's Radeon 3000 series.
GTX 200 Series, 100 series, 300, GTX 400 series, GTX 500, 400 GTX, 700, 600, GTX 280, GTX 285, 280, 285, 275, 295 GTX, 265, 200, 8000GTX series, AMD's Radeon 3000 series and breath
I think it's about time they stopped using bloody numbers, let's break the mould! What about calling them, I dunno, something like Gaylord Focker for the Epic, monster top end card and work down from there? All in agreement shout "aye"
lol :D
Ok then, "aye".
aye!
I agree that it's a given that we will see a whopper of a Kepler GPU (500+ mm^2) from Nvidia at some point. The "all-in" mega-GPU seems to be their trademark.
The difference this time around is that Nvidia may not need their behemoth GPU in order to take the performance crown from AMD. If this is the case (i.e. GK104 outperforms the 7970), then there is no market pressure forcing them to rush out their most complex, high-end GPU. So we might not see it for a good few months...
It's really actually looking more and more likely that the 7970 is really exactly as good as it should be, just heavily underclocked due to power constraint.
The most interesting thing really about the +70-80% performance per "real" gen, is that power usage has roughly speaking gone up at about half that rate.
Someone did a nice list on semiaccurate.
Past generations:
7800gtx --> TDP = 100w --> 110nm --> 81w ( 3Dmark)
8800gtx --> TDP = 177w --> 90nm --> 132w (3dmark 2006) -->
gtx 280 --> TDP = 236w --> 65nm --> 178w (3dmark 2006)
gtx 480 --> TDP = 250w --> 40nm --> 262w (Crysys W) --->
7800gtx 512M (95w 3dmark 06) / 8800gtx 768M
1600x1200 4xAA & 16xAF ==> +107% performance / +38% power consumption
8800gtx 768M / gtx 280 1G
1600x1200 4xAA & 16xAF ==> +64% performance / +34% power consumption
gtx 280 1g / gtx480 2.5G
1680x1050 or 1920x1200 4xAA & 16xAF ==> +83% performance / +47% power consumption *assuming (gtx285 12% more perf than gtx280)
So basically speaking over the past 3-4 big generational jumps we've seen essentially power increase relatively to performance increase, IE donkeys years ago power increased by roughly 1/3 of performance, the next big gen power increased by roughly half of performance, and last time power increased by a bit more than half of performance.
THe only thing you could say for almost certain is that to maintain the 70-80% performance increase we would likely have required, bare minimum, a 35% power increase also.
That is likely why Kepler will either blow through the 300W single gpu barrier, or be heavily clock limited.
AMD has, in my mind, female genitalia'd out of this fight by releasing a 7970 at 20-30% lower clocks than it could apparently easily have had, to keep power at similar level to last gen while a "real" 7970 could likely have used 300W in gaming and potentially more than that in furmark/gpgpu stuff.
From what I can tell almost every reviewer could overclock their 7970 to the max possible with default voltage, which is 1125Mhz, and with a new bios and a mild voltage bump everyone seems to max out at 1250Mhz, and that is on the stock cooler AND with decent temps still, that is over 30% faster, and memory is overclocking well also.
I think the only "disappointment" in the 7970, is that AMD have tried to force it to be a 200-225W card in normal usage, when in reality as per every previous gen, it needed a likely 40-50% power bump to get its 70-80% faster.
With 30% higher clocks it would quite easily thrash both the 580gtx and destroy the 6970.
But yes, ultimately the problem is how do we have 40-50% power usage increase every single new gen. Years ago it meant going from 40 to 60W, to 90W, to 150W, but that scaling is now getting a bit out of control. Idle power usage is improving dramatically and I think we're well before the point where running a single gpu with 350-400W is somehow dangerous or expensive when it can use sub 20W at idle.
But again the big question for kepler will likely be more a case of, will it be big and neutered to under 300W. Because for Nvidia, well Nvidia tdp is 250W, and in stuff like furmark both could go basically to 300W and a bit over, a 40-50% power increase would be even more problematic.
IS that one of the reasons we're seeing rumours of hotclocks going away, one of the fundamental reasons for higher leakage on Nvidia cards than AMD, quite possibly.
This is what becomes a reasonable power usage, someone with 2x 6970 now using rougly 400-500W, rest of the system and uses a 800-900W PSU, a 7970 single could probably get close "unhooked" power wise, but to double his performance you'd be talking about two cards using potentially 800-900W overclocked on their own.
I think the big kepler could be either, disappointing, or as default use way more than 300W, the ultimate "who did better this gen" will likely only be fairly and really seen with both cards overclocked on air on the stock cooler and see where the cards might be without power becoming the limiting factor.
