** Today Only 07/01/2012 - 09/01/2012 ** - Intel Core i5 2500K OEM Processor and Corsair XMS3 8GB DD
20 Jul 2009
The bleak North East arm pit of Britain
Today only we have 50 of the Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM at a stunning low price of £159.98inc saving £14inc!
We also have 25 units of the Corsair XMS3 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX8GX3M2A2000C9) This kit is priced at an amazing £59.99inc VAT saving £30inc on the previous website price.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £159.98 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £159.98 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX8GX3M2A2000C9) @ £59.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Two matched 2GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2000MHz performance using 4GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 8GB (2x4GB Module)
- Pin Voltage: 1.50-1.65V
Only £59.99 inc VAT.
ORDER NOW
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN
But but but, I could upgrade to a 2500k, motherboard AND RAM for that price (+£20) :(
Curse my Q6600 for being viable for so long.
I picked my one up on a daily deal on 18th November and it was £5.00 less than this. I wondered back then if I was purchasing too soon and should I wait as I bet prices fall in a month, glad I was wrong and glad I never waited ;)
Not sure 9-10-9-27 latency can really be described as Ultra-low latency settings! Not bad for the frequency but hardly ultra low think you would have to be going more down the Dominator route for 'ultra low'- latencies at this speed and capacity
Looking back at i5 prices, I think your celebrations are rather misinformed, unless you spent the £5 you saved on a winning Lotto ticket.
