Upgrade?
3 Jan 2012
Liverpool
Hi fellow Overclocker members!
This is my first post and first time using the Overclockers forums. I've had an account with Overclockers for years bit i've not took full advantage of the forums, so i will be using this a lot more from now on.
I'm in a bit of a dilema at the moment and i was hoping there would be some friendly good advice on what i should do.
I bought the Titan Nero about 2 years ago now. It's quite an old system, but i've upgraded over the period.
I cant remember the original specs but i basically ended up upgrading the;
CPU to a: AMD Phenom(tm) II X6 1055T Processor, 2800Mhz
GPU to a: ATI Radeon HD 5770 GDDR5 1GB
MB to a: Gigabyte GA-MA790X-UD3P
My system works great, but its not the best, and when it comes to playing the latest of games, it's struggling quite a bit. For instance, SWTOR is on high, but all the settings in CCC are set to performance rather than Quality, and i'm getting pretty sick of seeing poorish graphics still, and yet have to put up with 30-40FPS.
My full spec of the computer is:
PSU: Antec 400W
CPU: AMD Phenom(tm) II X6 1055T Processor, 2800Mhz
GPU: ATI Radeon HD 5770 GDDR5 1GB
Memory: Corsair Memory DDR2 2GB XMS2-6400 CL5 240 DIMM x2
Motherboard: Gigabyte GA-MA790X-UD3P
I am DEFINETLY Buying the new ATI 7970 3gb card when it comes out, as this would be a serious upgrade for me.
So i will need a new PSU. I was thinking: http://www.guru3d.com/article/cooler-master-silent-pro-hybrid-850-watt-psu-review/4
I cant seem to find that one on the Overclockers website, maybe its slightly different but a link would be great because knowing my luck i'll end up buying the wrong one.
So i'll have 2 new upgrades once again. A new GPU and PSU.
Now because im only running on 4gb DDR2, my computer recently has started to take longer to load and is doing my head in a little bit.
So this is the dilema:
I either buy 2 more sticks of DDR2 and add to the board
OR
I decide on a new Motherboard, and then depending on the Motherboard, New CPU (AMD or Intel, im not sure at the moment), New ram and i'm thinking of a much better case and cooling system. I would have to build the system around the graphics card, as i will want to Crossfire some time in the future (first time!)
Money is NOT an issue here. But obviously the less i spend the more beer i can get for myself.
I love computers and im up for learning new things all the time. But i'm still a bit of a noob when it comes to Overclocking and RAID, seeing whats the right MB for me, right CPU etc. Theres only so much you can read, the rest you have to figure out for yourself. For instance i want to be able to learn how to overclock, and i want to be able to overclock a new system. But first i'll need some advice from a few people to get me going. If i can get some advice, then i'm fully assured that even if i dont decide to overclock, i've got a really good system.
I don't even know whether its worth upgrading to a new MB and having to get new DDR3 Ram. Depending on the MB i get also depends on whether i get a new CPU, because obviously they are both different Chipsets.
I look forward to reading your replys and i'd like to thank you in advance.
Hi and welcome to forums
Firstly I'd just go for the GPU & PSU upgrade and see how you get on, if you're not happy with the performance still and want to upgrade again then IMO youd be as well going for new mobo/cpu/ram and going Intel route rather than flogging a dead horse as it were
Re the particular PSU, no OcUK dont appear to sell that exact model, but they do have many other excellent PSUs, and if money is not an issue, you dont really get better than the Corsair AX series
A new case can be done as a separate issue, and theres many to choose from, though the particular one will depend on your requirements, you mention new cooling, is watercooling a possible option? This can greatly effect case selection
Another possible upgrade for a good boost in general performance/snappiness would be to get a SSD for your OS/main apps/games, these are a lot more responsive than normal mechanical HDDs
Hope that helps a bit
The AMD 7970 will be pci express 3, your motherboard is only 1 and as far as im aware there no AMD boards that support pci express 3. Maybe its time to change camps ?
Thanks for the replies, appreciated.
I'll have a look at those psu's when I get home from work.
Definitely interested in water cooling. I've wanted to try it for a while now but been to afraid incase a pipe blows. I'll need to read into that a little before making a choice there but I'm leaning towards that.
With the PCI-E 3/2 or whatever, its the first I've read of it and I didn't know of different models of PCI-E. Would anyone mind explaining?
Not much to explain PCI-E 3 is 2x the bandwidth of PCI-E 2. But I don't think any card on the market has saturated (exceeded the bandwidth of) PCI-E 2.
So in short I wouldn't worry. Also with the memory I don't think it's the size that is slowing you down I would imagine it's the speed. They are probably around 800mhz, but nowadays you can get 2000mhz kits for low prices :)
So my recommendation is to buy a kit like that, you will need a DDR3 compatible motherboard (pretty much all newer motherbords).
Regards
Okay, so i've spent the past 2 evenings looking up different pieces of hardware, but before i go any further, i'd like to see what others think of what i have put together so far.
As said in previous posts, I'll be upgrading my current system with a:
PSU: Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply
GPU: ATI Radeon HD 7970
Then later on in the year (Feb/March) i'll be doing a complete revamp which will include the following:
CPU: Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM
MOBO: Gigabyte GA-Z68XP-UD4 Intel Z68 (Socket 1155) DDR3 Motherboard
RAM: Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9)
SSD: Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK)
PSU: Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply (which i will already have)
GPU: ATI Radeon HD 7970 (which i will already have)
So thats what i've got so far, i'd like to see what you think, and if its worth swaping XX out for something a little cheaper but better for Value, or something thats a bit better but price difference is minor.
Once i've got these parts confirmed (I wont buy till end of Feb by the looks of things, so if its worth waiting for XX then please let me know).
So i need to figure out:
CASE:
COOLING:
Maybe a Blu-Ray Drive, thinking of hooking this system up to my 42" to watch movies on in the evening.
I'll also want to allow for another ATI Radeon HD 7970 as i want to try XFIRE out.
P.S. I checked on the Gigabyte website to double check the CPU was supported by the board, and it was. Just thought i'd mention because it does say LGA1155 on the chipset and i wasnt so sure they would match.
Thanks again.
CASE:
COOLING:
Thanks again.
No, you've done your homework well, apart from I would drop the CPU and mobo for Ivy bridge and it's accompanying chipset motherboard depending on how much later it will be.
All the rest is sweet but I would obviously look to get cheaper, better things nearer the time. However I feel like you are looking in the right directions.
So you're saying wait till the Intel i7-3770K CPU comes out and get that with a compatible board?
Seems logical considering that they will be at a similar price.
I didnt know of the new Intel IvyBridge CPU's so thanks for the heads up. Any idea this year?
April (projected), performance should be slightly better, cooler etc. Pretty standard, but considering it's the same price-ish it's a no brainer.
Best of luck.
okay so i've been reading up on Watercooling this evening.
I've put together some items, was wondering what you all thought of it. Bare in mind that i read the article on watercooling, and i read that its a better fit for 7/16 on a 1/2.
RAD: Hardware Labs Black ICE SR-1 360 Radiator (assume i need 2 1/2 connectors?)
PUMP: Laing D5 Vario Pump -T12 12V DC Pump (assume i need 2 1/2 connectors?)
CPU Waterblock: EK Supreme HF CPU Waterblock - Copper Plexi (assume i need 2 1/2 connectors?)
RES: EK Multioption Reservoir X2 250 Advanced
FAN: Scythe Gentle Typhoon 120mm 1450 RPM - 3pin x3
TUBE: Masterkleer Hose Pack PVC 7/16 UV-Reactive Orange 3.3M
This will be on a ATI 7970 GPU and an Intel i7 3770K CPU so looking for something that will do these.
If there is a better/value way of putting this together or whether its worth buying a kit, then let me know please, help is appreciated.
Thanks again
Thanks again
Okay everything you listed stands out as being fine, there not bad choices at all.
Whoever told you that is wrong, use 1/2" and just get suitable fittings (compression fittings).
Are you planning to cool the 7970, I sure would if your going for a "real" water cooling loop not like the h70 or similar. If so you would need a gpu waterblock and probably want an extra radiator. Up to you...
So you're saying go for a Quad Radiator with 4 fans, as i do want to Watercool the 7970, but i'll have to wait for plates to do that. But thats fine as this system wont be built till April anyway as i have to wait for the ivybridge to come out.
Yer at least, it all depends on how much your overclocking...
I wont be overclocking all that much for the first month or 2 as i want to read into it a lot before doing it, as i've only overclocked my 5770 via CCC, but im wanting to be able to do much more than just that.
Well for example you would want watercooling if you plan to OC a 2500k to ~5GHz
