the box arrived with a UK power adapter?
Im just wondering if this is normal as most manufactures wont provide you with a warranty if I have a product intended for singapore in the UK etc?
arrived with an adapter.. a separate one... same thing happened when I bought my dodgy import Canon 40D. I just wanted to make sure it wasn't a dodgy import![]()
opening the psu will void its warenty, you need a tool to remove the plugs from cables, that way if you needed to return it you can just remove the sleaving and no one will know.
