They definately are good i too just like you was going to buy it last week, but then i changed my mind and got the 6950 because i was willing to splash out a little more cash ; ]
I couldn't really afford to spend anymore.
If the time comes and I want more performance, I could just dual these right?
If your motherboard supports Sli and you have a decent enough PSU.
Then yes, you could. And it would be awsome!
Yes, if your motherboard supports sli.
^ Would my motherboard and PSU allow me to add another 560ti at some point?
Should do, because the 560ti is quite power efficient.
I'm not sure this is accurate and if anyone uses it anymore but i remmber this sort of thing being used in the past..
http://www.thermaltake.outervision.com/
my 580 died and am using a 560ti now got to say not bad card running bf3 on 1920x1080 and got to say its handing it most things are set to ultra getting 50-60 fps even with big fire fights
