- 5 Mar 2006
- everywhere
I've got one on my car (every OPC car comes with a 2 year one along with the 111 point check). It's about £800 + £200 odd for the 111 point check for every additional year and is 100% well worth it.
If you have a car that can have the warranty put on it then do it. You get locked into OPC servicing and OPC parts and not modifying the car (although Gibbo has found out with official Porsche parts you can do a bit) but it's well worth it.
Look at WillGill, a £30k+ car has been sat outside his house for what seems like forever (well over a year) as it wasn't under the OPC warranty and threw up a £12k bill!
My opinion is if you are getting a Porsche and are not a millionaire then get the warranty put on it for the £1k a year it costs and it's total peace of mind.
I've had my car back for 1 or 2 little things and I've just phoned up and said "X and Y isn't right" and then book it in and fix it without issue.
Do it. I wouldn't have bought a Porsche if they didn't offer the warranty as who can afford to pay a £12k bill when it just pops up out of the blue.
[TW]Fox;20982189 said:Will Giill, I wish your MSN worked more often than your Porsche![]()
The flipside is that I believe that something like a Porsche shouldn't throw up big bills, it should be the epitome of German reliability, it's not a TVR or something.
I accept that all cars have small issues, I'd expect alternators, starter motors and the like to fail but it seems more common these days that some pretty expensive cars throw up £10k+ bills which I think is totally unacceptable from a top marque.
Surely Porsches are designed to be driven hard and should be able to withstand pretty much anything. Hell, Honda Civics seem to cope with countless boy racers bouncing them off the redline from cold so why can't a £70k car?
Mine is 2 year/20k service and I've done 4k since i bought it 8 months ago.
I'm unsure if I should service it after 12 months (and roughly 8k), Porsche say not to, the internets and other owners say you probably should.
It's the £600-£800 question.
An oil change cost less than £100
At an OPC?
Would the rest of a normal service not be worth doing then after 12 months?
It just the oil which counts, do it yourself or take it too a specialist.
I suspect OPC would do it but you'd be paying their labour rates
Mine will only visit an OPC for the 2yr servicing and/or warranty work. The in between oil services and consumables I shall do myself or get a specialist to do.
I wouldn't know where to start with an oil change on a normal car let alone the Boxster where you can see naff all of the engine.
My best friend owns an independent non specialist garage so maybe I'll get them to do it. Is it really worth it though when Porsche say 20k/2 years is fine?
Its upto you. But oil and filter will cost your roughly £60, throw your mate £40 to do it, I just would not leave oil in any car for 20k miles, especially as a high performance engine.
Porsche have quite a few engine failures on these cars and the 3.4l in the Boxster/Caymen is quite prone to failure, who is to say the 20k interval is not a contributting factor?
For sake of peace of mind, I'd just do it, as the cost is £100. You may have warranty but do you really want the stress of a failure? Though of course I am not saying a failure will happen, but I change all my cars with 10k or less oil change intervals, oil is cheap, just seems like a good idea to do.
