now can you see that there is no top entry for hose fittings only via the bottom.
Problem?
been looking at your log and its going to be awkward getting the tubes into the gpu block where you have the pump at the moment.......
also how do you find that pump and res.? is it noisy at all.? reason i ask is im possibly going to get one them soon.........but might actualy go for the 4.0 pump as ill be running 1 x 240 , 1 x 200 and 1 x 120 rads..........
thanks for the vid jay...much appreciated.....seems very quiet to me there on that video........
regarding your card.......how about you fit 2 x 90 degree connectors to each connection on the graphics card block, that way they will be pointing up...........
then go from the outlet of the cpu into the vga block...then out of the vga block back to the pump...???
http://www.overclockers.co.uk/showproduct.php?prodid=WC-136-EK&groupid=962&catid=1529&subcat=1852
Are these the ones you're talking about to fit them to each other to create the 180 degree angle?
Thats what im worried about, the flows really good atm so dont want to ruin it.
Any other suggestions?
