- 24 Jul 2006
- Hoddesdon, London, UK
Currently building a rig with a 2500K that won't go past 4.4Ghz without insane volts, 1.38v LLC almost max for 4.5Ghz stability but seems to be priming away atm at 4.4Ghz 1.345v. Not the best board, Asrock P67pro3 but a 2600k i have here does 4.8Ghz easily on it at 1.38v LLC level 3 (lower is higher on this board).
Funny you mention 45x, the chip seems a bit more stable and can prime at 4500Mhz with 1.365v when clocked to 102.3x44 but it eventually flakes out with failed test after 2-3hrs, however same vcore with 45x100 fails with BSOD 124 at that volts within half hour. Tried PLL overvoltage etc.. no luck.
? Have tried as far as 1.4v bang on with PLL and 4.6Ghz, Windows would not even load. Now the funny thing is, seems with a Vertex 2E Windows will load but prime will eventually crash, with the Agility 3 it would hang on the boot screen, tried PCH volts incase it was possibly a SATA 3 issue but no change, its a B3 revision anyhow so should be fine, however Asrock haven't updated the bios in a long time and i wonder if the Agility 3 might be a bit finicky with an older rom.
