C2D vs C2Q vs SB i3
8 May 2011
London
I'm planning on building an office PC, and I was wondering what would be best. It would be used for mainly MS Office, and occasionally light video and image editing. Thanks
Using a quad will reduce the amount of time it takes to edit a video so I'd go with that as the other two options are both dual core.
Sorry to hijack thread, but RJC can you help me with some problems, can't seem to PM you. Check my recent threads please? Thanks
Will do, give me al little time to read through :)
Thanks, I spose it all comes down to whichever one is cheapest - my mate says he can sell me a C2Q + Mobo
Indeed if your on a budget and then system is at a good price :)
The C2Q is a q6600. Looking at benchmarks, I really don't know. For just everyday office/internettings, would the i3 be best?
EDIT: i3 2100 looks best as the q6600 only wins on video editing/rendering, and even then, not by much. I'll go with that unless anyone (except cleeecooo - it's his q6600) has anything else to say
Done a couple of build below, one would allow you to install a K series cpu and allow you to overclock, and he second one would not allow anyoverclocking.
Your basket
Product Name Qty Price Line Total
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £95.99
(£79.99) £95.99
(£79.99)
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
(£70.82) £84.98
(£70.82)
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £23.99
(£19.99) £23.99
(£19.99)
Sub Total : £170.80
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £36.06
Total : £216.36
2nd option:
Your basket
(£79.99) £95.99
(£79.99)
MSI H61M-E33 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** £46.99
(£39.16) £46.99
(£39.16)
(£19.99) £23.99
(£19.99)
Sub Total : £139.14
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £29.73
Total : £178.37
Your basket
(£79.99) £95.99
(£79.99)
(£70.82) £84.98
(£70.82)
(£19.99) £23.99
(£19.99)
Sub Total : £170.80
DPD Next Day Parcel
Total : £216.36
I like the look of that, but with case, psu etc. Thanks guys
Your basket
(£79.99) £95.99
(£79.99)
(£70.82) £84.98
(£70.82)
Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £49.99
(£41.66) £49.99
(£41.66)
Cooler Master Elite 430 Windowed Case - Black £39.98
(£33.32) £39.98
(£33.32)
(£19.99) £23.99
(£19.99)
Sub Total : £245.78
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £51.51
Total : £309.04
Use "CMDOUBLE" in the voucher box and save £20 on the case and PSU.
I did not add hard drive or dvd drive, you can use on board graphics via the HDMI port on the motherboard.
Your basket
(£79.99) £95.99
(£79.99)
(£70.82) £84.98
(£70.82)
(£41.66) £49.99
(£41.66)
(£33.32) £39.98
(£33.32)
(£19.99) £23.99
(£19.99)
Sub Total : £245.78
DPD Next Day Parcel
Total : £309.04
Thanks. Just to check, Windows 7 Home Premium (Retail) won't have any problems with being put on a new PC (formatting the old PC's HDD ofc) will it?
EDIT: I also have an old ATi HD 2400 in an unused rig. What's better? That or Intel's HD 2000?
Nope, you be fine. You might need to use the the automated telephone activation if its fails to do it over the internet
I would probably use the onboard GPU, this will be fine
+1 for the i3 option - it performs a good deal better than a Core 2 in lightly threaded scenarios and when running multithreaded apps it still holds its own.
Plus, it also gives you SATA3/USB3 connectivity options and the ability to upgrade to sandy bridge quad cores or Ivy Bridge CPUs in the future as well as use DDR3 RAM (which is now much cheaper than DDR2 which most Core 2 boards use).
One thing I would suggest adding is a small and cheap SSD to install Windows and your key applications on (something like this). This will allow for very fast loading of the OS and the applications, plus everything tends to "feel" much smoother.
