http://www.memtest.org/#downiso
There is a USB stick version or an ISO you can burn to disc. V4.20 is the latest. Let it run for 7 passes which will take several hours.
When the bios has problems, I am guessing this is a dual bios mobo? It will turn on for a few secs with fans, then turn off and back on and boot from the 2nd/safe bios settings. But you would get a message on the very first screen saying overclock or something was wrong.
Good luck m8
Yeah sounds to me like something may have gone wrong with the overclock. If you lower it I guess it would post just fine. You can lower it just fine but I would drop a message over here to customer support:
http://forums.overclockers.co.uk/forumdisplay.php?f=116
OCUK for me have always been good fixing issues and helping. You don't want to mess with overclocking settings if you do not know what you are doing, you could up the voltage and do some damage.
I don't trust hibernation. Always had problems with it, even 'sleep' although win 7 seems to do better.
S3 sleep resume usually points to memory,what qpi/vtt or imc voltage you using? Using latest BIOS? Set dram voltage to what's printed on your ram?
Hate how it is always on on a fresh install. Had problems also.I don't trust hibernation. Always had problems with it, even 'sleep' although win 7 seems to do better.
If you have overclocked then you shouldn't use sleep/hybernation. 9/10 it won't be able to wake up, something to do with not bing able to supply enough V back to the CPU to resume. I had this on my first overclock. Fans spin up, stop, spin up, stop. After a CMOS clear and a reboot its fine.
Ah doubt I have a stick big enough and have no discs.
That's what happened. So what do you recommend?
