** Dual D5 Bay Res for less than £70? **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Oh, Go on then :)
Alphacool Repack - Dual Laing D5 - Dual 5,25 Bay Station @ £69.98 inc VAT
Alphacool‘s high-class solution for integration of single or dual VPP and TPP pumps into a cooling loop.
Pump top and reservoir in one component offer many advantages: Easy mounting, compact dimensions and appealing looks! All this is combined and perfected in the new Alphacool Repack. But Alphacool would not be Alphacool if these new products would not feature innovations which were before not available in this configuration!
The Alphacool Repack – Dual Laing D5 – Dual 5.25” bay station is for designed installation in the front of an enclosure. For mounting two vacant 5.25” drive bays are required. Mounting of the pump(s) can be done individually or in a dual configuration. For both configurations all required material is included. Dual operation can be configured to couple the pumps serially or for parallel operation. The pumps always draw the coolant from one combined reservoir.
Technological innovations featured in the Alphacool Repack:
So far the information about the reservoir sounds like a standard reservoir, but the developers have had many great ideas to solve common problems:
Anti Cyclon:
Different than standard solutions, where the coolant is guided around many edges and corners, still leaving micro-bubbles in the coolant, this reservoir uses a completely new technology. A new kind of filter is placed in front of both pump inlets, marked with “in” & “out”, eliminating the problem of micro bubbles at the core.
Filling:
On standard Slot-In reservoirs filling was a hassle: Unscrew, pull out, fill, fixate again. And during filling a third and fourth hand would always come in very handy, as it is always a very difficult operation to fill in the coolant. Enough! The front is equipped with a filling straw which can be released with few turns, and as it is hollow it can be used for filling of the reservoir. For this we recommend the filling bottles or straws from our portfolio.
The looks:
The front, which is mainly what remains visible after mounting, is beautiful to look at: Plexi, Acetal, fill level indicator and filling straw in combination with the typical Alphacool copper look make a great appearance! The next step is the creation of lighting effects for the coolant. From the left and right side of the reservoir LEDs can be inserted, both 3mm and 5mm in site. The highlight: a 10cm long cold light cathode can be inserted from the top for maximum lighting performance! In combination with the LED it is even possible to implement different colors within the reservoir. Creative users will surely create even more effects with the Heatmaster and find new ideas.
Looking at all of these features, more power, great looks and comfortable handling, a simple question comes up: Why only high-class, this is already First Class!
Technical specifications:
Material: Plexiglas/Acetal, Brass
Color: Transparent/black/Copper
Connection threads: 4x ¼“
Dimensions (L x W x H): 172 x 148 x 84mm
Mount for 10cm CCFL
Opening for 2x 3 or 5mm LED
Conforms with ROHS
Extent of delivery:
1x Alphacool Repack - Dual Laing D5 - Dual 5,25 Bay Station
4x Mounting screws
Allen key
Please note: In order to use the single version, screw plugs must be ordered separately.
Only £69.98 inc VAT.
ORDER NOW
Really like the look (and price) of this. Do you know if the filling straw has any kind of seal so the res can be completely filled without it leaking out around the tube?
it has some kind of O-Ring in there. I am not entirely sure how it works. but it is certainly sealed.
picture 5/6 on the product description shows the o-ring in situe through the plexi :)
dual and single loop i think. wonder how this bleeds compered to the koolance dual bay d5 res. although why does it have just one fill port?
it's just that there doesn't seem to be a divider between the res to make it into two :eek:
aye just noticed that me self, and screwplugs to be ordered sepratly is preety bad imho should be all in one.
think i'll stick with my koolance v1.3 one. i dont trust perspex since i had a xpc dual bay res leak on me a while back, granted this is alphacool and prolly better build quality
Noted, this could rule out the 2.5L reserator shell with this in its place then, would also mean I only have 2 tubes leading out of my PC rather than 4.
You make a good argument Cleeecooo, you still recommend the OCUK D5+top combo for £85?
Its one of the few parts I have committed too yet.
I will add it to the basket once I have price on the radiator and ask rjkoneil if I can throw the lot into a single order!
