raven rv03 + kuhler h20 620
6 Jan 2012
hi all
i have just bought new raven rv03 case and i'm planning to use my kuhler inside.
where should i install it?? 5.25 bay or top of the case? also i want it in push-pull config with 2 fans installed. does the fans should be identical (rpm)? cause right now i have 3 different fans with different spec.
also in ravens manual silversone reccomend graphic cards that have fan blowing exhaust air to the rear slot. i'm using two GV-N460SE-1GI do You think the are going to be ok?
regards
A small difference in fan speed won't cause any problems.
In regards to the graphics card dumping the heat directly into the case as apposed to exhausting out of the system, this will create a bit more heat inside the case but again won't cause any issues.
Generally these coolers are better than the standard coolers even though they do dump the heat directly but the graphics card is the one of the two hottest components in the case.
Off topic - Do you have any issues with the air penetrator fans?
I have the same case and one of my fans is faulty, switch to low speed and the fan turns off, high runs at the low speed. Informed Silverstone, they said RMA the case.
i have just received my raven rv03 ;]
man it's huge in comparison with my old case. if rv03 is that big how big is HAFX or antec1200.
all fans are working fine. penetrators are slow on low and fast on hogh. and aren't that loud either.
regards
regards
Agreed :)
using an antec kuhler in a raven makes the kittens cry ? In a case as big as that surely a nice custom loop would look a lot more beautiful than the borg like tubing of the antec ?
i assembled my rig and when i wanted to turn it on ... nothing happened!
i double checked the cabels but still no power. then i connected psu directly to the mians and it worked! the psu cable inside the case is broken .. and i was worried about the fans:/ gonna contact the seller asap.
