Hi guys, I think I've just gone and burnt my card to death...what do I do?
Upon starting my computer today i get a long beep then 8 short beeps from my mobo and nothing on screen whatsoever (light stays orange on monitor so nothing at all is sent to screen) so turn it off and look up what it means on lappy, apparently its video memory or video card failure. I've recently moved my PC so initial thought is no problems its just not seated properly.
Then when I was reseating the card as you do, the computer turned on by accident when the card WASNT slotted but WAS plugged into power, cue mad panic to turn off pc, followed by burnt smells
I now get the same beep followed by 8 beeps and absolutely nada, and the GPU does smell burnt, although there is no visual damage.
Is the card a goner do you think? The smells were 100% coming from the GPU My specs are...
8800GT
MSI K9N mobo
2GB corsair RAM ddr 2
load od hard drives
Corsair 450w psu (recently replaced, old antec one died)
I've already made sure all connections inside the case are firmly in place.
I'm going to get a VGA cable tomorrow to plug into onboard (only got DVI at the min) to check thats still working.
If I plug into onboard and it works, i guess the trusty old 8800 is dead
If so what is the best card to get for 70 - 80 quid that will give me similar or better performance, I'm not up to date these days.
Any help or suggestions much appreciated!
8800GT
MSI K9N mobo
load od hard drives
