Overclocking i5 2500k
15 Nov 2011
Oxford
Hi i am new to overclocking and have no idea on how do do it.
I have a i5 2500K cpu and MSI Z68A-G45 G3
Currently i am using in OC genie mode which brings it upto 4.2GHz but would like to get it higher.
also are there any programes i should get to test it, i have prime alreadly but is there anything else?
thanks
Cheers for the link, is the any software i need to download? would 4.6 be the highest i could get it to? i've got a antec 920 cooler
Still can't overclock, i tried following the link, n it didnt work :/
could someone please tell me what i have to do
would like to get it to 4.5 or 4.6 if poss.
currently on 4.2 using oc genie
Best off doing any overclocking in the bios. Clocking an SB CPU is a cakewalk, it really is. You only have to touch two settings, multiplier and vcore. Start off with a multiplier of 40 (to give you 4Ghz) and a vcore of around 1.3v. Work the multiplier up from there, one step at a time whilst testing for stability in between. If you get a BSOD then either tweek the voltage up or back down on the multiplier. Note: use realtemp to keep an eye on temps (shouldn't go over 75c while stress testing) and CPUZ to keep an eye on vcore.
My CPU is pretty much an average clocker, and takes 1.28v to get stability at 4.3Ghz with temperatures hitting the mid sixties during prime stress testing (just to give you some idea). I could easily get it to 4.5Ghz but it was a little too toasty for my liking at this speed.
tried at putting it to 45 with auto vcore, and went passed first bit just before windows loads the screen goes black with a small white line in the top left of the screen
is this ok?
if u cant see the pic
4.5ghz, 1.336vcore -cpuz
intelburn test on max
max temps across cores: 60, 73, 68, 68
idle temps across cores: 29, 36, 30, 36
That looks OK - temps could be a touch better but nothing to worry overly about. IBT is a really good initial indicator of stability - once you're stable with that, try running Prime for 12 hours or so (or as long as you can). Very little will load your CPU like IBT does - expect around 10C lower temps when Priming versus IBT.
