*** Official OcUK Minecraft Server - Discussion and Rules ***
Server is back up.
I'm aware of the issue with sheep and I'm looking into it.
Many thanks to those that helped test - and additional thanks to Sylvet for providing an old version of bPermissions that allowed me to work around the problems.
edit:
https://bukkit.atlassian.net/browse/BUKKIT-30
I'm not sure what timeframe we're looking at for this. Looking into workarounds.
I don't know the answer, but as that was posted in November I can't imagine that being the problem.
Animals following/reproducing worked up until 'that' restart earlier today. But as I say, I don't have an answer for it :D :(
Jens Bergensten @jeb_
Did you notice we updated Cobalt to v101a last week? playcobalt.com Also, I think we'll update Minecraft to 1.1 tomorrow...
Yeah. I was in a rush when I posted that. We think it might be another plugin (which I stupidly forgot I'd put on there - long day).
It may start working again next restart...
Animals (following and breeding) are working fine with current Bukkit RB(1597), Bperms 1.9.2 and AdminCmd 5.10.2, no matter what I do to the configurations I can't reproduce the problem. A conflict with another plugin seems the likely culprit. Had a quick look at the new code-base of Bperms, looks like you would need to redo that configuration from scratch given the extent of the changes.
Yeah. I was most of the way done with recreating the permissions config files when you mentioned that you had an older version of bPermissions. From what I could tell (admittedly there may be a workaround that would become apparent with more extensive testing) the newer versions of bPermissions don't like AdminCmd - full stop.
I've laid the stone base for the track approaching your little wooded area. Can you let me know whether the track will be too close/far, high/low if it continues in a straight line. It is still at the same height as the main line it came from at the moment.
Yep, that is fine :D
