- 23 Apr 2009
- Cheshire
To echo what the guys have mentioned above, if you have a 1080p LCD TV then that means there is a fixed number of 1920x1080 (2.073 million) pixels on the entire screen.
If you chop down the image to (say) 1/4 the original area then you will be looking at a 20.5in image (similar size to many modern PC monitors) however in this area there would only be 0.691 million pixels (960x540) - which for PC use would be rubbish and the pixels would be the exact same size as before.
The best way to get the full 1080p and apparanetly smaller pixels is to either put the TV further back from your eyes or invest in a PC monitor (which have much smaller pixels).
That said, as you are using a TV for PC work - your "issue" with the image looking poor may be more to do with improper settings. By default many LCD/LED TVs have image processing options like edge enhancer and noise reduction turned on. These features are often very useful when you are running non-ideal video inputs like DVD or Freeview - however for a "perfect" 1080p signal from a PC these features just make the image look worse. May I ask what make and model TV you are using?
