Caporegime
- 29 Aug 2007
- Auckland
Yeah, it was. Sorry
What's even more mind-blowing is that, because we don't know the absolute conditions needed for life - and because everything in the universe projects an infinite gravitational pull, no matter how small - then life may exist on this planet only because of the absolute positioning of everything else in the entire universe! Freaky, eh?![]()
[FnG]magnolia;21020963 said:Conjecture and A Levels doesn't make for a great debate and certainly doesn't deliver an answer. As far as I know, there is no one here who is capable of both fielding and asking questions regarding the topic, in a any sense that is actually worth bothering with.
This is why we can never find the absolute mass of something, because, no matter where in the universe it is, it will still be affected by mavity of some sort![]()
Even really really heavy things are likely too far away to have any effect.
however the effect would be indirect, not direct.?..yes?
Each object having an effect on its neighbour and then that effect alters the effect that object has on it's next neighbour and so on.....so while the effect of a distant object may not directly affect the Earth, indirectly it would?
We're talking truly vast distances for some of these objects though, and on that scale the tidal forces on Earth (tiny diameter in comparison) are going to be a small number at the end of a lot of zeros. Not forgetting that these same objects are also exerting attractive forces on the whole solar system.
A useful example; astronauts aren't weightless because they've escaped earth's mavity, it's because they are in freefall (both them and the vessels they are in).
I was speaking in relative terms though.....of course the influence of a body a 100m lightyears away has no direct effect on the Earth, however as a Universal concept it does have an indirect effect, as does everything within the Universe have on everything else....
I think that was the point being made, not that everything has a direct effect on any given point.
A variation of The butterfly effect if you like.
I am not physicist or mathematician, but it seems reasonable to assume that while the black hole the otherside of the Galaxy has no direct effect on me, it does have a direct effect on its neighbours which in turn alters the effect it has on its further neighbours and so on....all the way to that influence, however small, however indirectly, however immeasurably having an effect on me.
A Universal Connection if you like, where eveything in the Universe has an effect that alters that Universe in someway.
I'm probably not explaining it very well tbh.
Disagree, I'm not sure you are quite appreciating how vast the Universe is and how small some of those effects are.
2 1 kg weights 1 light year apart would attract each other at 8.33106526×10^-75 ms^-2
That means it would take 6.15159817x10^31 years for each to move 1 planck length (16.162×10-36 metres) closer to the other (ignoring expansion of the universe or any other effects). For contrast the universe is only currently 1.37×10^10 years old.
It would also take them a whole year before they started accelerating.
Assuming they were instantly teleported there, sure. Although I think we can gloss over 1 year in 60 million trillion trillion.![]()
Tbh magnolia is right, when did people become so convinced of the value of their opinions?
Was that really so hard?
wikipedia said:the equatorial bulge and the effects of centrifugal force mean that sea-level gravitational acceleration increases from about 9.780 m·s−2 at the Equator to about 9.832 m·s−2 at the poles, so an object will weigh about 0.5% more at the poles than at the Equator.[3] [4]
wikipedia said:The gravitational effects of the Moon and the Sun (also the cause of the tides) have a very small effect on the apparent strength of Earth's mavity, depending on their relative positions; typical variations are 2 µm/s² (0.2 mGal) over the course of a day.
