Wonder how long it'll be before we have holographic screens
Any write ups other than a youtube link?
:[CES 2012] Samsung has something very interesting over at CES this year (apart from the myriad of Smart TVs and other consumer electronics, of course), where the transparent screen that you see is capable of fitting into just about any window – as long as it does not go larger than 46″ in size, and will feature a pixel count of 1366 x 768. It is totally transparent, although what you see is private, so folks who are outside will not be able to know just what you are viewing, other than wondering how come you are daydreaming all the time from your room or store window. Does Minority Report or Mission: Impossible ring a bell with this technology? No idea on how much this will cost should it be commercialized, but whispers on the CES showfloor is that these will enter production from next month onwards.
It'll have limited application - most people 1) wouldn't want to stare out of their window and 2) wouldn't want to put something expensive on display because it'll be nicked or vandalised.
What happens when it goes dark outside as well? There's no backlight that I can see.
So far as I can tell it's another toy for posh glass+chrome corporate reception areas.
At CES in Las Vegas Samsung is demoing a new touchscreen display technology that is, yep you guess it, see-through.
Dubbed the Samsung Transparent Smart Window, the transparent touchscreen LCD tech can fit a window any size up to 46-inches and deliver a resolution of 1366 x 768 pixels allowing full interaction at the same time.
Users will be able to supply content via HDMI or USB, and in our demo it reproduced video perfectly quickly jumping between different menu options like checking travel details, the weather, what was on television, or even just using it as an expensive blind to block out light.
There is no word on price or where we will see this next, but the possibilities are endless thanks to our love of glass.
One such possibility as we overheard during our demo at CES is in submersibles where you want to move the instrumentation out of the way of a glass viewing area. That's really niche, but imagine car designers being able to remove the dashboard of your car altogether, or Minority Report style computers that are just sheets of glass rather than the big bulky monitors that you have in your office at the moment.
To show what's possible beyond the window, Samsung was also showing off the technology with a smaller monitor. The same screen technology can be used to create smaller screens with higher resolutions. In this example it measured 22-inches and offered a higher resolution of 1680 x 1050 pixels.
And if you are worried that others will be able to see what you are doing from behind the screen. Don't. Samsung say that the technology comes with a privacy screen that works like a one-way mirror.
This is extremely early stages. There is some kind of lighting, over wise you wouldn't be able to see the widgets.
The demo had a box behind it with a big light in it. In a window you would have daylight behind it - except when it's dark.
You'd need to have some sort of side-lit or overhead light to be able to use it at night.
There is something there, how it works I don't knowSo you've got the "blinds" app on to block out the outside world and are standing at the front window, stark naked with morning wood, doing a bit of browsing.... all of a sudden there's a power cut....![]()
Look at the screen, you need LIGHT to get colours in to a screen.There is something there, how it works I don't know
It's at the top of the box behind it. How do you think your LCD works?
