This review put me off of it:
http://www.hardocp.com/article/2011/11/09/asrock_z68_extreme4_gen3_motherboard_review/6
So I went for the Asus in the end.
Got three of the Asrock Z68 Extreme4 Gen3 boards, never had any problems with them, no inverted mouse issues, & two of them are o/c to 4.6ghz , & each with 16gb of memory.
This motherboard is just sooooo, ridiculously, insanely, good, I achieved this benchmark at 5.1 GHz on AIR. How can this be possible?
http://3dmark.com/3dm06/16383529
AsRock Z68 Ex4 G3, [email protected] , G. Skill RipsawsX 8GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
hello all just ordered the Asrock Z68 Extreme4 Gen3 Intel Z68, any thoughts on this, reviews seemed good, but be good to hear from any owners, after any tips tweaks or must do's
this review put me off of it:
so i went for the asus in the end.
You've definitely made the right choice Jimlad![]()
Are you installing the OS to a SSD or a Mechanical Hard Drive ?
Ok only have your SSD connected, no mechanical drives.
Go into the bios and set storage to AHCI.
Set your Ram to XMP profile or set the timmings manually (CAS 9-9-9-24) and set the DRAM voltage to 1.500v.Edit Just noticed your ram Corsair XMS3 may need 1.550v ( but don't set it over 1.575v)
Then follow this order to install Windows 7
http://forums.overclockers.co.uk/showthread.php?p=20964529#post20964529
Once you're up and running here's a few tips for starting your overclocking from post #20 onwards
http://forums.overclockers.co.uk/showthread.php?t=18360757
Oh and don't forget to do a build log with some nice pics![]()
thanks mate, what a helpful post, really appreciate that.![]()
No probs bud, I've subscribed to this thread, so if you need any more tips post em up here
Oh and if you do a build log with pics post a link to it here aswell then I can follow your progress![]()
