I have built many systems in my time but I have never ventured into watercooling. I think this has been mainly out of fear of the potnetial complexity involved in getting all the right bits and then putting it together correctly. So my current system I tried to cheat and got a H50, and all I can say is I was disapointed.
Now I have decided to start a water cooling project so I have come here looking for some help. This will be a 100% new build and my starting point will be a corsair 800D case.
The aim of my project is mainly looks but also want to get good performance. Likely hardware will be an 1155 SB CPU and a Z68 motherboard, with a 6970 GFX card. I would want to watercool both CPU and GPU.
For looks I would quite like to use a bay res and coolant that is UV reactive (is this possible)
so I was thinking of maybe this for the res ?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-013-KA&groupid=962&catid=2133&subcat=
or
http://www.overclockers.co.uk/showproduct.php?prodid=WC-066-AC&groupid=962&catid=2133&subcat=
however this is when I get stuck, what pump(s) would I need to get for this and what other fittings would I also need to get
coolant wise I was thinking of http://www.overclockers.co.uk/showproduct.php?prodid=WC-006-MH&groupid=962&catid=1531&subcat= as I like th look of it and with a light fitted in the case I think it would make a nice effect ?
sorry for the ignorance likely displayed in this post.
I am looking at maybe laying down 400 quid just for the water cooling parts
or
