** DUAL LOOP RESERVOIRS - PRICE DROP! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Following the awesome discounts on XSPC GPU blocks, I have found another treat for you today.
this pricing will maintain as long as I can hold it.
XSPC Dual 5.25” Split Bay Reservoir - Multi Fascia @ £39.59 inc VAT
XSPC Dual BayMulti Fascia Split Reservoir Perfect For Dual Loop Systems
Specification:
- High quality Acrylic with Clear fascia
- 2x LED Mount with Blue LED
- Water-tight seals and individually pressure-leak tested.
- Fits in Two (2) 5 1/4 Drive Bay
- 2x Easy to install/Refill
- Ideal for dual loop systems
- Dimensions: 149 x 104 x 85.5mm
Included:
- 1 x Blue LED
- 4 Mounting Screws
- Black and Silver Brushed Aluminium Fascias
Was £47.99 Inc. VAT
Only £39.59 inc VAT.
ORDER NOW
