Gaming Desktop £500 max
IC3
IC3
3 Dec 2011
Hi everyone i finally deciaded that iam going to build a system but before that have 2 questions.
Should i buy i5 2500k but i never did overclocking or should i buy i5 2400.
Another question should i buy radeon 5870 for about 75-80 quid or stay with my gts 250 1gb and get more money for new card.
Also last option buying gtx 480 zotac amp of eb*** for 150-160 quid and wait in till i get more money for rest of the parts.
My monitor is 1920x1080 full hd.
For now i only have 500 pounds.
The i5 2500K is probably worth getting if you can afford it, even if you don't overclock. However at that budget an i3 might be best. What do you need included for £500? Just the tower?
Os, mouse, keyboard, monitor?
5870 sounds like a good deal, if it's in good condition. The 480 is good, however for the price and your budget, the 5870 will do pretty much everything you want, while not having massive power requirements and heat issues. If you plan on getting money to improve your machine later on, then it depends how long you feel you can stick with the GTS250. A 5870 is a good step up. The 5870 is roughly equivalent to a 6870.
For your budget, I would get a i3.
YOUR BASKET
1 x Cooler Master CM-690 II Lite Dominator Case with GX650w Power Supply £99.98
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
1 x Sapphire ATI Radeon HD 6750 1024MB GDDR5 PCI-Express Graphics Card £79.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £69.98
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £39.98
1 x Sony Optiarc AD-5280S 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £498.00 (includes shipping : £11.75).
I've put a card similarly priced.
HDD's are so expensive, but there you go, unless you can re-use a drive, which would have to be SATA.
As usual, it is always best to save your money to get the good stuff. However, this will be a nice gaming rig with a 5870, which can be upgraded later to a 7xxx generation GPU (when the prices become sensible), and a 2500K CPU.
You can also get a Antec DF10 wiht a Antec TP-550 / TP-650, and use the Antec promotional code AG15 code to get 15% off the bundle.
YOUR BASKET
1 x Antec TruePower New Modular 550W '80 Plus Bronze' Power Supply £69.98
1 x Antec Dark Fleet Series DF10 Gaming Enclosure - Black £59.99
Total : £528.89 (includes shipping : £12.50).
I have monitor,mouse,keyboard,hardrive 750GB western digital
Whats the point having i5 2500k if i dont overclock, iam only going to use that turbo bost that intel has so 3,8Ghz for me is even to much :)
Why not keep the option opened for later? Free 30% boost, can't be bad, surely.
However if you already have a hard drive (and optical SATA drive?), then that saves money for a quad-core CPU. Unless you also need the OS.
If you don't need a HDD:
YOUR BASKET
1 x Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card £179.99
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £101.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £58.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £39.98
1 x BitFenix Merc Alpha Gaming Case - Black £32.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £531.91 (includes shipping : £12.50).
That's what I'd suggest, though what olivier_renault suggested is good too.
I'd get the 2500K anyway when you can afford it, because you might decide to overclock it and it will have more resell value I'm sure.
do you need a operating system ?
and as everyone else says get a i5-2500k it will last you 4-5 years. long after all the rest of ur components wouldve been replaced.
id look for a 2nd hand card mid range cards can be picked up for decent prices. That should free up money to get 8gb 1600mhz ram and the rest of ur compnents
No i have windows 7 64bit home premium and also i have mouse keyboard monitor and hardrive which i bought 4 months ago
Thats what iam thinking of with 5870.
That will work.
I would pick up the Vengeance LP RAM for that price.
Although the CX600 is not 'technically' a gaming PSU, it will handle the 5870 ok. I would have preferred the TP-550, or the XFX Core 550. Even though they have lower wattage, they have more power delivered to the CPU and GPU. They are both Seasonic design.
If i win 5870 and i get in budget of 520 max then i get 2500k
Best gaming CPU on the market. Can't go wrong if you have the budget.
And if you mean 'win' from the auction site, I would be wary. I would never buy a second hand GPU from someone I don't trust 100%. These things get overclocked, cooked, maltreated, and sold as DOA more often than I can count.
