New build.. help?
14 Jan 2012
Hampshire, uk
I got a budget of £1000 -1500 for the main rig, the main uses will be Internet, AutoCAD, Photoshop, photo editing large res pics) watching videos and the odd games (thou use a games console mostly for this) (also like to try video editing in the near future)
It must support usb3.0 and latest Sata, would like it to be very much future proof for upgrading, and fast for now too.
(For now it will be a air-cooled pc thou interested in water-cooling in the near future and to over-clock)
Rig spec list:
CASE: Fractal Design Define R3 Black Case - USB3.0
MOBO: MSI Z68A-GD65 Gen.3
CPU: 2nd Generation Intel® Core™ i7 2600K 3.40GHz Socket LGA1155 - OEM
CPU Cooler: Be Quiet! Dark Rock Advanced
SSD: Corsair 120GB Force 3 SSD CSSD-F120GB3-BK
RAM: Corsair Vengeance LP 8GB (2x4GB) DDR3 PC3-12800 C9 1600MHz Dual Channel Kit
GPU: MSI GeForce GTX 560 Ti Twin Frozr II/OC NVIDIA
PSU: OCZ ZX Series 850W 80+ GOLD PSU Fully Modular PSU
(or should i go upto a MSI X79A-GD65 (8D) Intel X79 Socket 2011 Motherboard and Intel Core i7 3930K CPU???)
I will be getting two LED 22” Monitors for multi dual desktops was looking at the LG IPS225V-BN LED 21.5" IPS Monitor, or might go bit bigger.
What are your thoughts??
Looks good. COnsider the Crucial M4 SSD, always recommended as fast and reliable.
You may find 16GB of RAM useful if you are editing.
GPU is good, if you don't play games too often then not much point in spending much more on that.
Not sure about monitors sorry!
socket 2011 is expensive and "extreme" unless every second really counts when editing, then the i7 you've selected will be fantastic :)
EDIT: with those changes
YOUR BASKET
1 x intel core i7-2600k 3.40ghz (sandybridge) socket lga1155 processor - retail £239.99
1 x msi geforce gtx 560ti oc twin frozr ii 1024mb gddr5 pci-express graphics card £184.99
1 x crucial realssd m4 128gb 2.5" sata 6gb/s solid state hard drive (ct128m4ssd2) £154.99
1 x asrock z68 extreme4 gen3 intel z68 (socket 1155) ddr3 motherboard £144.98
1 x ocz zx series 850w '80 plus gold' modular power supply £124.99
1 x fractal design define r3 midi tower case - black pearl £84.98
1 x bequiet dark rock advanced cpu cooler (socket lga 775 / 1155 / 1156 / 1366, am2 / am2+ / am3 / 754 / 939 / 940) £41.99
2 x corsair vengeance low profile 8gb (2x4gb) ddr3 pc3-12800c9 1600mhz dual channel kit (cml8gx3m2a1600c9) £39.98 (£79.96)
total : £1,073.39 (includes shipping : £13.75).
you don't have an hdd in there, do you have one from a previous build?
case is personal choice so if you like that one, go for it!
also i changed the board, the one you specced is out of stock, and i've heard good things about the asrock one :)
good psu, review:
http://www.techpowerup.com/reviews/ocz/zx_850w/8.html
However, consider this one:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XF&groupid=701&catid=123&subcat=1497
You really don't need 850W for a rig like that :)
I will look into the Crucial M4.. The Corsair has 510MB/s Write over the M4 with 175MB/s and has Random Write 4K: at 85,000 IOPS over 35000 IOPS on the M4, what advantage difference is this SSD? (spec found at **********)
i'm thinking of getting 16GB now as well
You don't have an HDD in there, do you have one from a previous build?
Yes I have a "Western Digital 1.5TB sata/ 32mb Cache WD15EADSA" for storage
Also I changed the board, the one you specced is out of stock, and I've heard good things about the Asrock one :)
I first considered the "Asus P8Z68-V Pro Intel Z68" but was persuaded to the MSI one
