It makes a difference of 1,612,800 pixels. That's 78% more pixels than 1920x1080.
You'll notice a difference but to be honest, you're probably better seeing a comparison in the flesh before deciding on how much you want to spend.
Just went from a 1920x1200 to a 2560x1440 monitor before xmas.
The extra space is brilliant, and i was surprised that my 6950 2gb will still run most things on full details at 60fps, Dirt 3 for example, runs maxxed out at 60fps (with an old i5 @ 4ghz).
Previously had a 120hz 1080p monitor and would far more recommend a bigger 27" than the 120hz way for loads of reasons.
Over at Sweclockers, there was a article last week about new 27-inch monitors with a resolution of 2560 x 1440 pixels (16:9),and IPS at 120 Hz. coming later this year.
How does this work bandwidth wise? DVI wont do 120hz at that res and im sure displayport cant either so its HDMI 1.4 correct?
