My pump is running almost the same (two 120's rather than 240's) with no problems, its a OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo..
2 GPU and a CPU judging by the link in is sig.
kd
You obviously have money... buy a better pump![]()
yeah i wouldnt want to use that pump with all that resistance. maybe even 2 ddc's rather than the D5
well in my mind, the extra rads would have a negative effect if the flow rate from the pump is low due to resistance from the blocks and rad. If its not flowing fast enough then you cant get the water away fast enough the heat gets contained in the block or even the first rad and everything else in the loop is rendered a waste.
Are you still selling that CPU block? I keep bumping that thread to buy it off you
And I wish I had money....![]()
