Turtle Beach x12 wire is too long!
3 Jan 2012
As the title says, my turtle beach x12 wire is way too long for my PC. Most of it is still in that Velcro tape, and when I put the cable on the floor, it weighs down the headset making them uncomfortable. Is there anything i can do about this?
Can you take a picture of the wire? The only way not to void your warranty is something like a tie and clip the leeway together.
You may be able to strip it and stick a bit of insulation tape on it ;)
If you use it exclusively with the PC, you could attach some kind of clip, maybe an adhesive one, to maybe the underside or side of your desk, which can hold any bundled cable. That should stop the cable pulling your headset, and keep the cable out of the way. As long as you leave enough slack. :)
Could you not bundle the cable closer to the PC so the weight is taken by the connector rather than the headset?
