New here, first computer build, thoughts?
14 Jan 2012
England, Kent
Hi there,
I will be buying myself a new computer at the end of the month, I have a budget of £1,100, and i'm looking to build a computer that can do both gaming and a lot of video, photo & 3D editing for university work.
Now i'm in no way a novice to computers, but this will be my first personal computer so i want it to be a beast of a computer.
CPU: Intel Core i7-2600K 3.40GHz
CPU COOLER: Antec Kúhler H2O 620 CPU Watercooler
GPU: EVGA GeForce GTX 560Ti 2048MB
MOBO: Asus P8Z68-V PRO GEN3
PSU: OCZ ZT 750W Modular Power Supply
HDD: Samsung SpinPoint F3 500GB SATA-II 16MB Cache
CASE: BitFenix Shinobi Gaming Windowed Case
MEMORY: G.Skill RipJawsX 8GB (2x4GB)
DISK DRIVE: LG GH24NS70 24x DVD±RW SATA ReWriter
EXTRA FANS: Akasa AK-274CG-4GNS 120mm Green LED Fan x 2
WIRELESS: Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E
OS: Microsoft Windows 7 Home Premium SP1 64-Bit - OEM
Total: £1,101.72 - w/o postage: £1,085.22
I will be adding another 8gb of the same memory in about 2 months, and also adding an SSD to use as a boot drive.
So what do you guys think?
personally id run it on air gelid does a superb cooler for 25 quid shaving 70 off there also the case id a bit over the top annd the graphics are average at best and the ram you can equal or better for cheaper.
Personally i wouldn't get the 2600K and get an i5 2500K saves a lot of cash and the difference isn't noticeable.
p.s chuck the extra £80 at a better GPU.
From what people have told me the i7 2600k's hyperthreading is better for video and photo editing, which is the main reason i need the computer.
Check This Does it justify £70 extra? It's up to you but personally you could easily push the i5 to deliver similar timings and many programs allow GPU encoding which is commonly faster than CPU encoding.
Bare in mind those are benchmarks and it may be that the programs being used by the OP could use the extra threads well, and the i7 can be pushed just like the i5 can
Yes, but rendering via the GPU is generally faster so why not save some cash on the CPU and buy a better GPU which would half the times of rendering videos and animations by around 50%?
If you are going to be doing a lot of video, photo & 3D editing and the software you use makes use of hyperthreading then I would go for the 2600k. This is the sort of application that makes it worth paying the extra cash for.
Good choice of motherboard by the way :D Very impressed with mine.
All software uses CPU, not all is optimised for GPU acceleration.
OP what software will you be using?
Photoshop, Sony vagas, 3DS MAX, Maya, Fraps, xSplit, Adobe After effects & Adobe Flash, Thats just what i can think of off the top of my head right now.
I was under the impression the i7-2600k would be a much better choice then the i5 for what i need the computer for?
I think i'm sticking with the i7-2600k, i feel even if i didn't need it, it's something i would rather just have.
Sorry I should explain. I'd recommend the i7 to you anyway, it's just whether you should get a better card to let you take advantage of the GPU acceleration.
Get what you specced, it's great!
