Cheap £20 graphics card won't run Movies/Games in 1080pGet a cheap 20quid graphics card that can do hardware acceleration
http://en.wikipedia.org/wiki/Unified_Video_Decoder
http://en.wikipedia.org/wiki/Nvidia_PureVideo
Could the i3 gain more GHz? and I will have to see in few weeks to see if I can raise my budget a bit to get the i5 2500KOkay fair enough, well if it fits in budget then get the 2120, as its slightly faster and you can't overclock the i3s.
Z68 allows overclocking ("K" version chips only such as i5 2500K)
http://en.wikipedia.org/wiki/LGA_1155
The 460 is good for gaming yes, although without a case in the budget you might be able to get a better GPU.
As I said, H67 doesn't allow overclock and the i3 can't anyway but it's ideal for gaming.
Why not consider an Intel atom processor on the nvidia ion platform? Perfect for htpc duty.
i5 2500K beats every AMD CPU?
